AC1082, AU6210HD, AX1073, GPD2856 и другие MCU/SoC
| | Сообщение # 251
ВIOS
Постов: 1332
Код ********************************************************************************
SDK BR17 Apps Soundbox ... ********************************************************************************
16.02.2019
ac690x.or32: file format ELF32-pi32
Sections: Idx Name Size Address Type 0 00000000 0000000000000000 1 .data 00000168 0000000000300000 DATA 2 .bss 0000461c 0000000000300170 BSS 3 .data1 00003460 0000000000340080 TEXT DATA 4 .bss_ram1 00001ab4 00000000003434e0 BSS 5 .text 00056236 0000000001000000 TEXT DATA 6 .version 0000001a 0000000001056236 DATA 7 .debug_str 0002b408 0000000000000000 8 .debug_loc 00023e5d 0000000000000000 9 .debug_abbrev 00000f6a 0000000000000000 10 .debug_info 0007f0ee 0000000000000000 11 .debug_ranges 00007ea8 0000000000000000 12 .debug_macinfo 00000001 0000000000000000 13 .debug_pubnames 000159d9 0000000000000000 14 .debug_pubtypes 0000e368 0000000000000000 15 .debug_line 00042b37 0000000000000000 16 .debug_aranges 000000a0 0000000000000000 17 .shstrtab 000000ce 0000000000000000 18 .symtab 00095c40 0000000000000000 19 .strtab 00016384 0000000000000000 ac690x.bin data.bin data1.bin Скопировано файлов: 1. F_ASCII_S.PIX F_GB2312.TAB F_GB2312_S.PIX menu.res ui_sty.sty Скопировано файлов: 5. 0.mp3 1.mp3 2.mp3 3.mp3 4.mp3 5.mp3 6.mp3 7.mp3 8.mp3 9.mp3 bt.mp3 connect.mp3 conn_hid.mp3 disconnect.mp3 discon_hid.mp3 echo.mp3 linein.mp3 low_bat.mp3 max_vol.mp3 music.mp3 pc.mp3 power_off.mp3 power_up.mp3 radio.mp3 record.mp3 ring.mp3 rtc.mp3 sd.mp3 usb.mp3 wait.mp3 Скопировано файлов: 30. WARNING: The specified KEY doesn't match the device KEY, use the device KEY. SPI nor flash online Device name :W25Q80. Device id: EF4014. Device block num: 16. Device block size: 0x10000 Byte. Device capacity: 0x00100000 Byte. Flash protect buffer select 1 Output binary file name=jl_isd.bin flash_id:0xef4014 flash_size:0x100000 flash_file_size:0x98000 protected_range:0x1 sys_cfg_file_addr:0x87c00 sdfile_head_addr:0x87c00 spi_run_mode:0xa10a spi_div:0x1 flash_base:0xf740 cfg_zone_addr:0x88060 cfg_zone_size:0x30 reserve_zone_addr:ee000 reserve_zone_size:12000
pll_sel:0x0 osc_freq:24000000Hz osc_src:0 osc_hc_en:1 osc_1pin_en:1 make flash image ok format addr:0xff000(Byte)--len:0x1000(Byte) erase sector: 255 Write File 2Disk physical address:0x00000000 Erase Flash block ...... 0 1 2 3 4 5 6 7 8 9 write data to block ...... 1 2 3 4 5 6 7 8 9 0 write file to Flash ok erase special area [BTIF] addr:0xff000(Byte)--len:0x1000(Byte) erase sector: 255 Для продолжения нажмите любую клавишу . . .
| | Сообщение # 252
Антрэ
Постов: 67
ВIOS, Где сам софт найти про софт (как пользоваться). Вообщем откуда оттолкнуться.
| | Сообщение # 253
ВIOS
Постов: 1332
Антрэ, А ты вообще как в программировании? Го в ЛС.
| | Сообщение # 254
Антрэ
Постов: 67
Микроконтроллеры программирую на асме. Си в данный момент дерзаю.
| | Сообщение # 256
Антрэ
Постов: 67
ВIOS, Да я сам не силен но вот разбираюсь потихоньку. Микроконтроллеры это одно на них инфы море. А тут интересно как китайцы лепят. Хотел вообще сначала поверхностно посмотреть что к чему. Делиться буду только вот пойдут ли успехи).Начал вот с 1082 просто с сборки вроде ничего сложного а подводные камни полезли в принципе как и везде куда без них.
| | Сообщение # 257
ВIOS
Постов: 1332
Антрэ, Хорошо, лови в лс ссылку, только там всё на китайском, но понять можно. Там и библиотеки, и source и утилиты, и компилятор, и так далее. Ну и IDE тоже.
| | Сообщение # 258
Антрэ
Постов: 67
ВIOS, Хорошо, спасибо.
| | Сообщение # 259
ВIOS
Постов: 1332
Антрэ, Эти микросхемы кстати очень похожи на PIC 32 DSP. У многих компаний микросхемы пин то пин, или даже софт писали одни и те же люди. По комментариям в исходниках можно понять. Не придумали они же свою архитектуру, просто куча лавочек (к слову, с большим оборотом бабала) которые заказывают это всё у одного изготовителя. И по минимуму их перепаковывают, чтобы была иллюзия выбора
| | Сообщение # 260
Антрэ
Постов: 67
Дак вот я тоже думаю что свою архитектуру не могли они придумать.
