Металлоискатель Шанс - 03HP
| | Сообщение # 11
Boltyara
Постов: 1212
ahmdi, Author's documentation
| | Сообщение # 12
ahmdi
Постов: 8
thank you all I have a question. how is the dept of this metal detector for a 20*20 metal? can work man just with a loop? if yes how?
| | Сообщение # 13
Boltyara
Постов: 1212
| | Сообщение # 14
ahmdi
Постов: 8
thank you boltyara this metal detector has 2 coils, a sender ans a reciever, is there any way to use just a coil?
| | Сообщение # 15
Boltyara
Постов: 1212
ahmdi, детектор работает с двумя катушками. Две катушки можно вставить в один корпус. The detector works with two coils. Two coils can be inserted in one box.
| | Сообщение # 16
ahmdi
Постов: 8
than you boltyara please see this picture and say. is that correct, when man puts sender coil and sender coil together?
| | Сообщение # 17
Andre-TT
Постов: 78
Yes, that's right
| | Сообщение # 18
ahmdi
Постов: 8
thank you Andre-TT i want to build a 60*60 coil, how must be diameter and number of wire?
| | Сообщение # 19
Andre-TT
Постов: 78
Coil 1mx1m has 16 turns wires of 1.5mm square for TX and 16 wires of 0.29mm square for RX. Coil 60x60 has 20 turns. It's all written in post №307
| | Сообщение # 20
Kuzmi4
Постов: 88
ahmdi, I also did the CHANCE-03 scheme with the changes. Changed the circuit and looked for another design of the coils. The information is posted on the forum. Please answer, what changes did you make in the scheme? And why?
