вот что у меня пишет с другим проггером...
Код
avrdude -C avrdude.conf -c apu_2 -P ft0 -B 14400 -p m8 -q
avrdude: BitBang OK
avrdude: pin assign -
MISO:4
SCK:2
MOSI:6
RESET:5
GATES:3
avrdude: drain OK
SET=> ft245r: bitclk 9600 -> ft baud 4800
avrdude: ft245r_program_enable: failed
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
RESET ... OK
avrdude done. Thank you.
Добавлено (23.04.2015, 15:59)
чатланен, ты говоришь выбрал 910 а в настройках я вижу 911
Цитата чатланен (
avrdude -C avrdude.conf -c avr911 -P com3 -B 19200
Добавлено (23.04.2015, 16:21)
странно щас нужно прошить тини45 и тоже не активны фьюзы...первый раз такое...в сообщения написано
Код
Programmer supports the following devices:
Device code: 0x13 = AT90S1200
Device code: 0x20 = ATtiny84
Device code: 0x28 = AT90S4414
Device code: 0x30 = AT90S4433
Device code: 0x34 = AT90S2333
Device code: 0x38 = AT90S8515
Device code: 0x48 = (unknown)
Device code: 0x4c = AT90S2343
Device code: 0x51 = (unknown)
Device code: 0x55 = ATtiny12
Device code: 0x56 = ATtiny15
Device code: 0x68 = AT90S8535
Device code: 0x6c = AT90S4434
Device code: 0xffffff86 = (unknown)
Device code: 0xffffff87 = (unknown)
Device code: 0x3a = ATMEGA8515
Device code: 0x41 = ATMEGA103
Device code: 0x43 = ATMEGA128
Device code: 0x45 = ATMEGA64
Device code: 0x5e = ATtiny2313
Device code: 0x60 = ATMEGA161
Device code: 0x62 = (unknown)
Device code: 0x64 = ATMEGA163
Device code: 0x69 = ATMEGA8535
Device code: 0x72 = ATMEGA32
Device code: 0x74 = ATMEGA6450
Device code: 0x76 = ATMEGA8
Device code: 0x78 = ATMEGA169
тини 45 не вижу хотя в списках есть...дибилизм какой тоДобавлено (23.04.2015, 16:25)
чатланен, воспользуйся CVAVR она проще и там у меня все норм
