eas
Понравился этот язык программирования, очень похож на Visual Basic, на котором я раньше учился. Но не могу к нему найти нужной мне информации. А именно прямого вывода на LED дисплей, чтоб прочитать десятки, сотни и единицы. Написал программу, но, она работает не точно, наверно из-за округления чисел, которые я не знаю как округлять, вот пример:
Код enable_digital_io() var word led alias ledA is pin_A2 pin_A2_direction = output alias ledB is pin_C0 pin_C0_direction = output alias ledC is pin_C1 pin_C1_direction = output alias ledD is pin_C2 pin_C2_direction = output alias ledE is pin_C3 pin_C3_direction = output alias ledF is pin_C4 pin_C4_direction = output alias ledG is pin_C5 pin_C5_direction = output alias d3 is pin_A0 pin_A0_direction = output alias d2 is pin_A5 pin_A5_direction = output alias d1 is pin_A4 pin_A4_direction = output const byte led_input[70] = {--a,b,c,d,e,f,g, 1,1,1,1,1,1,0, --0 0-6 0,1,1,0,0,0,0, --1 7-13 1,1,0,1,1,0,1, --2 14-20 1,1,1,1,0,0,1, --3 21-27 0,1,1,0,0,1,1, --4 28-34 1,0,1,1,0,1,1, --5 35-41 1,0,1,1,1,1,1, --6 42-48 1,1,1,0,0,0,0, --7 49-55 1,1,1,1,1,1,1, --8 56-62 1,1,1,1,0,1,1 --9 63-69 } procedure led_display() is --LED----------------------- var byte a,b,c,n n = byte (led/10) if n<10 then a = n b = byte (led-n*10) ledA = led_input [a*7] ledB = led_input [a*7+1] ledC = led_input [a*7+2] ledD = led_input [a*7+3] ledE = led_input [a*7+4] ledF = led_input [a*7+5] ledG = led_input [a*7+6] d1 = low d2=high d3=high ledA = led_input [b*7] ledB = led_input [b*7+1] ledC = led_input [b*7+2] ledD = led_input [b*7+3] ledE = led_input [b*7+4] ledF = led_input [b*7+5] ledG = led_input [b*7+6] d2 = low d1=high d3=high end if if n>10 then a=n-(n-(n/10)) b=n-(n/10)*10 c=byte (led-n*10) ledA = led_input [a*7] ledB = led_input [a*7+1] ledC = led_input [a*7+2] ledD = led_input [a*7+3] ledE = led_input [a*7+4] ledF = led_input [a*7+5] ledG = led_input [a*7+6] d1 = low d2=high d3=high ledA = led_input [b*7] ledB = led_input [b*7+1] ledC = led_input [b*7+2] ledD = led_input [b*7+3] ledE = led_input [b*7+4] ledF = led_input [b*7+5] ledG = led_input [b*7+6] d2 = low d1=high d3=high ledA = led_input [c*7] ledB = led_input [c*7+1] ledC = led_input [c*7+2] ledD = led_input [c*7+3] ledE = led_input [c*7+4] ledF = led_input [c*7+5] ledG = led_input [c*7+6] d3 = low d1=high d2=high end if end procedure------------------------------------------
forever loop led_display led=led+1 end loop
Витинари
Постов: 1503
eas, если быть точнее, он похож на всеми давно уже подзабытый Паскаль, что как бы намекает на "востребованность" JAL. Мой вам совет: учите Си (для которого и компиляторов, и документации, и примеров, и готовых библиотек валом). Тогда не придется искать решения по языку, на котором пишут полтора человека, один из которых - вы сами.
Egour
Постов: 916
Вздрагиваю вспоминая свои попытки освоить Паскаль... Си не в пример удобнее и человечнее.
